4.210 visninger
Vga One 12 euro5 2022 tunning {{forumTopicSubject}}
Hi guys,
Does anyone know how to delimit the new Euro 5 VGA? I have an One e5 model 2022. I just changed the variator for an Malossi sportive one, but stil doesn't run more than 33/35 km/h.
Does anyone knows what else should I do? I can't find the cable that I used to unplug from the CDI in the old VGA explora.
Thanks!
sep 2018
Følger: 1 Følgere: 16 Emner: 2 Svar: 1.009
jun 2019
Følger: 13 Følgere: 764 Scootere: 1 Emner: 136 Svar: 4.777
jun 2019
dec 2021
Følgere: 89 Emner: 27 Svar: 164
this it opens up for the ramp and it can run faster. to about 50-55 km/h
i must warn you , if they do it, you lose your warenty, and your exaust will burn so hot the heat resistant paint will flake off. and your exaust will no longer be rust protected.
Følger: 19 Følgere: 659 Scootere: 12 Emner: 152 Svar: 8.284
Can't be derestricted
mar 2022
Emner: 5 Svar: 11
jun 2019
It seems they've coded the parts to not be interchangable, and prevent illegal mods..
You're not the first to buy these and get disappointed when you find out they're not like the pre-2018 scooters we were used to.
mar 2022
Emner: 5 Svar: 11
My guess is you can see them in german and french tuner shops in the autumn. No earlier. Probably more likely to be winter or even spring 2023 before they'll be available anywhere
Then look what else you can get in that price range. Such as this https://www.dba.dk/piaggio-typhoon-30-km-t-kn/id-1090279775/
